Disegnata da Marc Newson (bruttina forse piu della Nikon 1) porta anche Pentax a competere con il settore Mirrorless...
PENTAX RICOH IMAGING COMPANY LTD. is delighted to announce the launch of the PENTAX K-01 interchangeable-lens digital camera in conjunction with the world’s thinnest interchangeable lens* - the smc PENTAX-DA 40mm F2.8 XS unifocal. This latest addition to the popular Pentax K series and the new lens were both designed in partnership with world renowned designer, Marc Newson.
Pentax has formally announced the K-01 K-mount mirrorless interchangable lens camera and a revised 40mm F2.8 pancake lens to match.
Built around a 16MP APS-C sensor, the camera can mount most of the lenses the company has ever made. It features sensor-shift image stabilization, a 920k dot rear LCD and can shoot at up to 6 frames per second. The rather interesting design is the work of respected product designer Marc Newson and features a logo of his signature on the base of the camera. The K-01 (which the company says should be pronounced 'kay-zero-one'), will cost around $749 body-only and $899 with the 'XS' version of the 40mm lens.
Key features of the PENTAX K-01 include:
- Durable machined aluminum frame under a stylish black, white, or yellow exterior.
- PENTAX mirrorless body design is compatible with 25+ million PENTAX K-mount lenses spanning decades.
- Large 16 megapixel APS-C sized CMOS image sensor with low noise image capture and multiple aspect ratios.
- Bright, high resolution 3 inch LCD with 920,000 dots.
- Full HD 1080p video capture at 30 FPS with h.264 compression (60 FPS at 720p) features outstanding video capture flexibility.
- Sensor-shift PENTAX Shake and Dust Reduction system is compatible with every mounted PENTAX lens.
- Fast 6 FPS burst mode is ideal for fast-action photography.
- Flexible ISO range of 100-25600 ensures gorgeous noise-free imaging in any lighting condition.
- Focus peaking mode provides fast and accurate manual focusing for critical focus applications.
Mi domando perche Nikon ha messo un sensore cosi piccolo nella serie "One" quando anche Pentax puo con un sensore APS-C!!!!
