D700 aggiornamento Firmware 1.01 pronto.
Ospite_ginger_*
, gen 20 2009 12:32
#1 Ospite_ginger_*
Inviato 20 gennaio 2009 - 12:32
Ho aggiornato il Firmware D700: tutto ok.
Inviato 20 gennaio 2009 - 13:00
C'? un nuovo aggiornamento?? E cosa aggiorna???
Walter
Inviato 20 gennaio 2009 - 13:34
Dettagli :
This service provides software for upgrading D700 firmware to v1.01.
The following improvements have been made in version 1.01
- When Custom Setting a4 Focus tracking with lock-on was set to Off in Continuous-servo AF, the lens drive moved gradually without achieving focus. This issue has been resolved.
- When the Speedlight SB-800 was mounted on the camera with flash mode set to Distance-priority manual (GN) mode, and then the exposure meters were reactivated or the camera was turned on, the distance information displayed on the SB-800 changed. This issue has been resolved.
- When the Multi-Power Battery Pack MB-D10 was mounted on the camera and an EN-EL3e battery inserted in the camera but no batteries inserted in the MB-D10, and SB-900 flash mode set to TTL auto flash mode, the flash mode changed to A mode when the exposure meters turned off or were reactivated, or the camera was turned off or on. This issue has been resolved. (This issue has also been resolved with SB-900 firmware Ver. 5.02.)
- An issue that, in extremely rare cases, resulted in noticeable black dots in images captured with Long exp. NR in the shooting menu set to On has been resolved.
- Manamah, displayed in the Time zone options for the World time item in the setup menu, has been changed to Manama.
Inviato 20 gennaio 2009 - 13:43
ossiaDettagli :
Con la versione 1.01 sono stati introdotti i miglioramenti descritti di seguito.
- Se Impostazione personalizzata a4 Focus Tracking + Lock-On era impostata su Spenta in AF-Continuo, l'attivazione dell'obiettivo avveniva gradualmente, senza ottenere la messa a fuoco. Questo problema ? stato risolto.?
- Le informazioni sulla distanza visualizzate sul lampeggiatore SB-800, venivano modificate quando il lampeggiatore era montato su una fotocamera con il modo flash impostato su Manuale con priorit? alla distanza (GN) e quando l'esposimetro veniva riattivato o la fotocamera veniva accesa. Questo problema ? stato risolto.?
- Quando veniva montato sulla fotocamera il Multi-Power Battery Pack MB-D10 senza batterie inserite e una batteria EN-EL3e veniva inserita nella fotocamera e il modo flash dell'SB-900 impostato sul modo flash auto TTL, il modo flash diventava modo A quando gli esposimetri venivano spenti o riattivati, oppure la fotocamera veniva spenta o accesa. Questo problema ? stato risolto. (Questo problema ? stato risolto anche con l'SB-900 con firmware versione 5.02.)
- ? stato risolto un problema che, in casi estremamente rari, provocava la comparsa di punti neri visibili sulle immagini acquisite con NR. lunghe del menu di ripresa ? impostata su S?.
- Manamah, visualizzato nelle opzioni Fuso orario per la voce Ora internazionale del menu impostazioni, ? diventato Manama.
Inviato 20 gennaio 2009 - 15:05
dove lo posso trovare?
come si fa ad aggiornare la macchina?
grazie mille
grazie mille
Jack
Jack
Inviato 20 gennaio 2009 - 15:10
nel sito per l'assistenza eurpea nikon: per Windows o per Mac
sulla pagina relativa trovi anche una piccola guida per l'aggiornamento e un... ehm... aggiornamento del manuale
in pdf
in pdf
Inviato 20 gennaio 2009 - 15:43
GRAZIE ALBERTO.
aLTRA DOMANDINA STUPIDA: SE IO NON POSSIEDO, NELMIO PC, UN LETTORE DI CF POSSO COPIARE L'AGGIORNAMENTO SU CD E FARLO FARE A UNA AMICO?
GRAZIE ANCORA E SCUSATE
Jack
Jack
Inviato 20 gennaio 2009 - 15:57
GRAZIE ALBERTO.
E cosa te lo impedirebbe ? Il tuo amico forse ? canonista e c'? il rischio che da lui il processo non funzioni ?
Inviato 20 gennaio 2009 - 16:00
si.... si pu? fare
ops........... sono stato precduto
Inviato 20 gennaio 2009 - 16:26
- Manamah, displayed in the Time zone options for the World time item in the setup menu, has been changed to Manama.[/i]
Fondamentale, direi.....ossia
P.S. Qualcuno che l'ha gi? installato mi sa dire se ? stato risolto il bug comune alla D300 per cui non si riesce ad impostare pi? di una funzione per i tasti personalizzabili+ghiera?
Quello ? l'unico bug "vero".... non usiamo Canon, qui!
#11 Ospite_Birzio_*
Inviato 20 gennaio 2009 - 16:59
Lo saprete di sicuro, ma ricordo che e' stato ovviamente rilasciato anche l'aggiornamento alla versione 2.01 per la sorella D3
Fabrizio
Fabrizio
Inviato 20 gennaio 2009 - 17:07
Fabrizio
Uhm.... Forse si, forse no.... Qualcosa mi pare di aver fatto ma non ricordo bene. E' vecchio questo aggiornamento?
#13 Ospite_acq749_*
Inviato 20 gennaio 2009 - 17:22
bene, Vi siete accorti che hanno unificato i 2 file di aggiornamenti A e B?
#14 Ospite_Birzio_*
Inviato 20 gennaio 2009 - 17:50
Assolutamente no: e' stato rilasciato oggi...fresco fresco!Uhm.... Forse si, forse no.... Qualcosa mi pare di aver fatto ma non ricordo bene. E' vecchio questo aggiornamento?
Fabrizio
Inviato 20 gennaio 2009 - 17:58
Fabrizio
Ah! Grazie, allora me lo vado a vedere.
Inviato 20 gennaio 2009 - 21:47
Fatto, e non ? esplosa....
Luca
Inviato 21 gennaio 2009 - 11:02
grazie rudolf, volevo solo essere sicuro.. il mio amico ? un canonista nikonista etc... usa di tutto insomma un minestrone.. per? ? proprio simpatico e il suo pc non fa differenze tra nikon e canon...io un p'? si per? vabbe.
hoops.. dimenticavo di ringraziare anche alberto73
Jack
Jack
#18 Ospite_brev14_*
Inviato 21 gennaio 2009 - 14:29
.....ciao ragazzi...ancora una volta devo ricorrere al vostro prezioso aiuto......
D700 e mac os X 10.5.6...cosa succede? la macchina non viene pi? vista come periferica USB una volta collegata al mac...questo non ? un grosso problema per lo scarico delle foto in quanto con il software in dotazione si riesce a scaricarle e gestirle perfettamente....ma il problema nasce con l' aggiornamento del firmware....
Dato che non vedo la macchina sulla scrivania del computer...come faccio a copiare l' update sulla scheda compact flash?
se qualcuno ha trovato il sistema....accetto molto volentieri suggerimenti......
#19 Ospite_brev14_*
Inviato 21 gennaio 2009 - 14:43
praticamente la macchina viene vista dal Mac solo in modalit? USB PTP mode e non come MSC (mass storage)...............
Inviato 21 gennaio 2009 - 14:59
E prima vedevi il volume?
A quanto ne so (ma prima di cinque minuti fa non avevo mai fatto la prova) la D700 non si ? mai potuta vedere come volume.
In ogni caso, per evitare rari quanto disastrosi sbalzi di tensione (e salvaguardare il maledetto sportellino di gomma?), dotati di un lettore di schede al pi? presto.
