D40 firmware update version 1.1
Modifications enabled and issues addressed with D40 A and B firmware Ver. 1.1
The product will be "Certified for Windows Vista".
Support for the new USB Media Transfer Protocol (MTP) has been added.
The PTP option in the setup menu's USB item will be modified to MTP/PTP. The icon will also be modified
The range of possible settings for the Date option in the setup menu's World time item will be changed to 2000-2099.
An issue that caused the ISO auto feature to be disabled, when a two-button reset operation was performed with ISO sensitivity set to any option other than ISO 200, has been resolved.
When attempting to edit images, which had already been edited using a computer, with options in the D40's retouch menu, the camera sometimes froze. Therefore, images that have been edited using a computer can no longer be edited using the camera.
An issue that prevented accurate recording of flash output value when manual flash photography was applied with use of the Nikon Speedlight SB-400 has been resolved so that flash output value is accurately recorded.
Errors in English, Polish, Swedish, and Traditional Chinese menus have been corrected.
When white balance is fine-tuned, "+" or "?" will be displayed with the following icons:
White balance mode icon in the shooting information display
White balance mode icon in the shooting menu
When the mode dial is set to a Digital Vari-Program and the AF-area mode setting is changed, the AF-area mode setting will no longer revert to the default setting with the following operations:
The camera is turned off
Monitor and exposure meters turn off automatically (auto meter off)
The electronic analog exposure displays will flash in the viewfinder and the shooting information display when:
The brightness of the subject exceeds the range that can be controlled by the camera, whether too bright or too dark
While in P (Programmed Auto) exposure mode with the built-in flash raised.
D80 firmware update version 1.0.1 - Windows
This data is protected by a Nikon License Agreement. Be sure to read the following License Agreement before proceeding with the download. By proceeding with the download, you indicate your agreement to the terms of this License Agreement.
When performing this Firmware Upgrade, be sure to upgrade both A and B firmware. Once firmware upgrade is complete, turn the camera off and then on again.
If these latest firmware versions are already installed on your D80 you need not proceed with download or installation of this Firmware Upgrade. Current firmware versions can be verified from the Firmware version item in the camera's setup menu.
Be aware that proper operation of your D80 is not guaranteed if either A or B firmware is upgraded to Ver. 1.0.1 while the other firmware is not upgraded.
Modifications enabled and issues addressed with D80 A and B firmware Ver. 1.0.1
The electronic analog exposure display will be displayed in the viewfinder when the brightness of the subject exceeds the range that can be controlled by the camera, whether too bright or too dark, in the following shooting modes:
Shutter-priority auto (S) or Aperture-priority auto (A) exposure modes with the built-in flash up
Programmed auto (P) exposure mode
Effects of processing performed when the Long exp. NR item in the shooting menu is enabled have been improved.
When attempting to edit images, which had already been edited using a computer, with options in the D80?s retouch menu, the camera sometimes froze. Therefore, images that have been edited using a computer can no longer be edited using the camera.
